Rear anti roll bar removal
Posted: Tue Oct 20, 2015 11:13 pm
by Gripped
Planning to remove and repaint as its pretty rusty.
It looks like it should be easy enough if the bolts undo. Is there anything I should be aware of? Is the ARB under tension?
Cheers :D
Re: Rear anti roll bar removal
Posted: Wed Oct 21, 2015 3:40 am
by Northern Bongolow
no. just undo it mate. soak yer nuts first though, if they break off then you have to drill them out and fit new bolts, not a 2 min job. if your fitting new rubbers then just warm em up with a blow lamp then wire brush them clean first, then spray.
Posted: Wed Oct 21, 2015 8:54 am
by Titan1995
Good idea to replace all the rubbers, brackets and drag links at the same time.
Did mine a couple of months ago as one of the brackets had failed.
Posted: Wed Oct 21, 2015 10:58 am
by Gripped
The rubbers and links are pretty new so I'll clean them up.
Thanks for the tips !
