Rear aircon temperature control in the front?
Posted: Thu Oct 15, 2015 5:43 pm
I'm hoping to interrupt the lead that goes from the rear aircons temperature control slider to the servo that operates the temperature flap so I can adjust the temperature from the front of the Bongo. The controls are the servo / electric ones, not the manual ones.
I'm not after anything fancy, a switch that turns the heat up to maximum or down to minimum would do just nicely.
Has anyone done this or can anyone shed light on what might be involved?
I'm only guessing but I imagine the slider is some sort of variable resistor in which case I could wire it to a switch that will switch in different value resistors.
It's a bit of an oversight I fancy that Mazda didn't do this given you can control everything else on the rear aircon from the front.
Maybe they know something I don't...
