Black alloy wheels for a Purple Bongo.....
Moderator: Ian
Purple Pixie
Post by Purple Pixie » Sat Sep 12, 2015 3:14 pm
Anyone running black alloys on their Bongo?
I'm looking for pointers for wheels that are not 'too spokey' in this I mean the spokes of the wheels are quite thick like Minilite wheels on the good old Austin Mini..... BUT flat and not curved in the face .... :roll: (Mrs B's shopping list)
I have 15" wheels on at present (the stock steel ones) and would like to stick to 15"'s
Are Mazda 626's the same PCD and inset/offset?
Cheers y'all!
1999 Ford Freda - "Purple Pixie"
Titan1995
Re: Black alloy wheels for a Purple Bongo.....
Post by Titan1995 » Sun Sep 13, 2015 6:47 pm
I run 18" RX-8 Wheels ....see a lot of owners use these.
Post by Northern Bongolow » Sun Sep 13, 2015 9:13 pm
you would want to check the load ratings of the 626 wheels first as a bongo is heavier than a car, even the rx8 wheels are known to crack.
Spencer54
Post by Spencer54 » Mon Sep 14, 2015 2:59 pm
Yep,
Black RX8's been on a while now
Trick is to use the right tyres, and not run on the standard 225 that are already fitted.
Go with 245/45/18 or 235/50/18.
Purple Pixie
Post by Purple Pixie » Mon Sep 14, 2015 7:24 pm
https://www.performancealloys.com/alloy ... isID=33457
This site appears to list wheels appropriate for a Mazda MPV .... 15 x 6.5" but we run wider tyres on the back but think the wheels are all the same
assuming the PCD is the same and the offset/inset is no different
JB
helen&tony
Post by helen&tony » Tue Sep 15, 2015 4:06 am
I've bought a couple of sets from these folk: http://www.alloywheels.com/ They have been more than helpful, and will suggest which models are correctly rated for weight. From memory, you want 590 (Kg) weight rating stamped on the wheels. Quite a few aftermarket wheels are higher rating than a few years back, as they can then supply a wheel which fits a wider range of vehicles. They all tend to come with a larger centre bore and the company supply spigot rings for your vehicle. I have 2 sets of alloys for summer and winter tyres for the Bongo...one in anthracite and the other anthracite and polished alloy. I run 2 sets for the Jeep, one with all season tyres, and the other winter tyres, but, frankly, the all seasons are pretty good in anything. I don't buy second hand alloys because you will never know if there is an inherent crack inside, because even a slight sideways shunt can damage an alloy, or hitting a pothole, and alloys are not good in a side shunt. I did enquire about getting custom wheels turned by a specialist, and they are VERY highly weight rated for van use, and the price was around £1000.00 and rather tempting, but that was polished alloy solid centres
Purple Pixie
Post by Purple Pixie » Tue Sep 15, 2015 7:56 am
http://www.wheelbasealloys.com/alloy-wh ... ck/15-inch
Decision has been made!
Brand : Borbet F 6J 5 Spoke
helen&tony
Post by helen&tony » Tue Sep 15, 2015 3:00 pm
Rather nice!...I had thought of 5 spoke for one set, but for the roads over here, the smaller spoke wheels are a bit stronger...namely that they spread the load and we have pretty crabby roads compared to the UK
Gasy
Post by Gasy » Tue Sep 15, 2015 7:15 pm
There not a bad price doctor
I'm not an alloy fan
But I do like the look of black ones ( and white ones remind me of rally cars )
And you should be able to keep one of your old steel wheels as a same size spare
Is the weight ratio acceptable ?
They will look nice
Gasy
Post by Gasy » Tue Sep 15, 2015 7:18 pm
I prefer the first pic you put up in Matt black ( but then I'm not a fan of shiny things )
And I like the little line detail
And I see there even cheaper
cmm303
Post by cmm303 » Tue Sep 15, 2015 9:53 pm
Gasy wrote:I prefer the first pic you put up in Matt black ( but then I'm not a fan of shiny things )
+1
Chris with BertieB
Puma931
Post by Puma931 » Tue Oct 27, 2015 9:47 pm
Return to “Pimp My Bongo”
