Courtesy lights
Posted: Wed Sep 09, 2015 5:29 pm
Hello all,
I've been tinkering on our T reg 1999 2WD Tin top since we took ownership in June. Thanks to all the contributors to the Q&A's and fact sheet, they've been invaluble. Fitted a TM4 combo which is a great for stress free journeys, leisure battery with VDR, also stress reducer after a weekends camping without EHU.
Having exchanged the internal lights for LED modules, I noticed two things:
1. The front light cluster works in manual and auto when the passenger door opens, it fails to light with the driver door although the door open warning light on the driver door works okay. Are there 2 connections to the door pin?
2. The central light works in auto when door opens but not when door closed, having had a look a the wiring, there are 3 wires from the ceiling connector to the light fitting, there are only 2 going from the connector into the roof void. So as soon as the door closes the pin, all power is cut. Any ideas?
Tried to find a drawing on-line, but can only find a blury one when magnified, may have to invest in the Bongo cd.
Cheers,
David
Cheers,
David
