Alternative to bongo header tank??
langtoftnick
- Bongonaut
Is there a more readily available alternative to the mazda bongo header tank? Want to replace mine as it is stained (yes I know they all are!) and has what looks like some stress fractures starting on the bottom which I think are weeping.
I have bought two second hand ones from ebay on the promise that they were from "working vehicles" and in "good condition". One was cracked, the other was so full of rusty sludge and crusted on gunk I wouldn't let it anywhere near my new radiator. It weighed 500g less once I'd flushed it out - cheaper to send back which was the good news.
A Tank is a Tank surely? If there's one approximately the right size and you can make bracketry to hold it in place, it doesn't have to be a £125 mazda original?????
Any ideas anyone?
Any ideas anyone?
Re: Alternative to bongo header tank??
Not seen anybody claim to have replaced it but worth reading the relevant section of the "great cooling discussion" here as to its function http://www.igmaynard.co.uk/bongo/forum/ ... 08#p438708
- haydn callow
The bongo tank has a lot of partitions inside.....these play a part in the degassing process.....I would not put a non standard one in there......not being able to see the coolant level dosnt matter if you have a low coolant alarm fitted.
windywatson
- Tribal Elder
I have a 97 & 01 V6, neither have stained/discoloured headers. Is this problem of staining just restricted to diesels? If so why would there be a difference?
Plus what's this about degasing! surly its just a tank for hot water to expand into & a reservoir of coolant in case of loss.
Windy-Watson
2001 V6 Tin Top
2001 V6 Tin Top
Good question. Might it be that the V6 is all aluminium whereas the diesel has an iron/steel block? I wonder if there is a V6/aluminium equivalent (chalkiness maybe if aluminium oxide is white in colour?)windywatson wrote:I have a 97 & 01 V6, neither have stained/discoloured headers. Is this problem of staining just restricted to diesels? If so why would there be a difference?
- haydn callow
I had a V6 with a badly stained tank......the bad staining often points towards a previous boil up when all the crud down the bottom of the engine/pipes is disturbed.
- haydn callow
langtoftnick
- Bongonaut
Having seen the diagrams of what is inside a tank, and the variations in pipe bore, blah blah blah Its definitely not just a tank!
Another example of the over complication that appears to be inherent in the bongo!
leave well alone!
leave well alone!
mikeonb4c wrote:Good question. Might it be that the V6 is all aluminium whereas the diesel has an iron/steel block? I wonder if there is a V6/aluminium equivalent (chalkiness maybe if aluminium oxide is white in colour?)windywatson wrote:I have a 97 & 01 V6, neither have stained/discoloured headers. Is this problem of staining just restricted to diesels? If so why would there be a difference?
Hi Mike , I thought it was aluminium head and cast iron block, you live and learn thanks.
'Might it be'.....? is a question not a statement. Are you saying the V6 is aluminium+iron? I'm no mechanic, have never seen a V6 engine, and my question was prompted by windywatsons observation on his V6s and by my having a Hillman Imp as my first car - it had an all aluminium engine. https://en.wikipedia.org/wiki/Coventry_Climaxrita wrote:mikeonb4c wrote:Good question. Might it be that the V6 is all aluminium whereas the diesel has an iron/steel block? I wonder if there is a V6/aluminium equivalent (chalkiness maybe if aluminium oxide is white in colour?)windywatson wrote:I have a 97 & 01 V6, neither have stained/discoloured headers. Is this problem of staining just restricted to diesels? If so why would there be a difference?
If the V6 has an iron block it might explain Haydns post about staining on his V6 header tank?
- Simon Jones
The V6 block is iron rather than alloy. Staining can also occur from rusty water as result of failure to replace coolant at it's specified schedule or the mix being diluted too much. Having also used RadWeld in an old car, I can also confirm it will turn any header tank a nasty shade of brown too unless it fully flushed out as soon as possible.
langtoftnick
- Bongonaut
Brick Acid.
That's what you need to get the gunk out. Got another replacement tank from Ebay, which wasn't too bad this time, but still had crusty rust in places which I didn't know might not flake off and block something. sooo
Checked the plastic type (PP) and looked up whether it's safe to put strong acids in it. Yes. Went to HomeBase and bought a couple of litres of Brick Acid (Hydrocholoric) and popped it in the tank for about 3 hours, swirling occasionally. Poured it out and flushed for about 10 minutes with a hose.
I can now see through it, there are NOT deposit even in the corners, and BONUS even got rid of enough staining so that I can see the water level!
(yes HSE People, gloves, glasses, safe disposal etc!)
langtoftnick wrote:Brick Acid.
Useful tip as the general belief was nothing would shift it.
- haydn callow
It will get rid of the crud but not remove the actual staining which impregnates the plastic....
