which breaker would you buy a replacement compressor from?
Tom_B
Post by Tom_B » Mon Aug 17, 2015 3:19 pm
turns out the compressor is U/S and I need a replacement - I have seen links to Bongo breakers - ideally it should be one that has been recently working - any views?
1996 AWD 2.5 Oil Burning, Slushbox, Stylish bullbars, AFT White & Silver.Unconverted. Aircon!
Re: which breaker would you buy a replacement compressor fro
Post by haydn callow » Mon Aug 17, 2015 3:31 pm
Search , Mazda bongo compressor, on eBay....loads on there
Post by Simon Jones » Mon Aug 17, 2015 5:46 pm
Double check the part number on yours with any you are considering as there have been a few variations over the years. It's not clear from your profile if yours is 2.5 diesel or petrol. If the latter, then there are definitely several a few versions over the years.
Post by rita » Mon Aug 17, 2015 8:34 pm
Simon Jones wrote:Double check the part number on yours with any you are considering as there have been a few variations over the years. It's not clear from your profile if yours is 2.5 diesel or petrol. If the latter, then there are definitely several a few versions over the years.
Its a AWD if that's any help.
Post by Bob » Mon Aug 17, 2015 8:44 pm
Diesel, then. :wink:
Post by Simon Jones » Mon Aug 17, 2015 10:56 pm
Thanks Mystic Meg. What would we do without you :)
Tom_B
Post by Tom_B » Wed Aug 19, 2015 9:39 am
Thanks for replies - I had understood that the A/c compressor is a sensitive bit of engineering and doesn't like sitting around unlubricated by the oil in the coolant - I guess my question was about whether this is the case and can I take a chance on a unit from a ebay seller or is there a Bongo breaking specialist that I can be more confident of and that the item is in decent condition.
Post by rita » Wed Aug 19, 2015 10:02 am
Most breakers just remove the parts label / mark them and put on shelves until sold, very few if any even test the units. Some will give you a guarantee and will replace the faulty supplied item, the one You want is the guarantee that covers return postage and package and (fitting and removing)labour costs, if you can get this deal I would say go for it
mikeWalsall
Post by mikeWalsall » Wed Aug 19, 2015 11:23 am
Maybe try a Bongo Fury member who is breaking his bus ..??
cmm303
Post by cmm303 » Wed Aug 19, 2015 12:56 pm
Surprised that bongospares hasn't been mentioned. they turn around a lot of bongos so maybe stuff does not sit on shelves too long.
Chris with BertieB
Post by mikeonb4c » Wed Aug 19, 2015 1:15 pm
cmm303 wrote:Surprised that bongospares hasn't been mentioned. they turn around a lot of bongos so maybe stuff does not sit on shelves too long.
Tsk tsk - not allowed to recommend anyone on here - PMs only [-X :wink: :lol: :-$ :-# :-" :-& [-( :-k 8)
Post by francophile1947 » Wed Aug 19, 2015 4:10 pm
Get it right Mike :roll: See Ian's post below -
Yawn. Here are some of the reasons we have these irritating rules in place.
1) Nobody objects to someone posting something along the lines of "I just want to recommend the good service I received from company xxx". That's fine. But....
2) .....but someone is always likely to chip in and say "that's not the experience I had". And give what appear to be good reasons for a grumble.
3) Company xxx then show up in the search facility and although there's only one negative comment, it's there for all to see.
4) Company xxx contacts Bongo Towers asking them to take the negative comment down as there are 2 sides to every argument etc. We refuse on the grounds of freedom-of-speech.
5) We receive a letter from solicitors saying if we don't remove it there will be consequences as we are ultimately responsible as we are the publishers.
6) We remove offending post and then receive complaints that discussion has been removed.
This (true) example was a minor irritant. In other instances we have had phone calls threatening violence. We can do without the hassle. And there have been too many other forums that have disintegrated in to a heap of shite because of arguments. I don't want it to happen here.
There's nothing wrong with getting opinions via PM if you need them. If you want to slag a company off do it via the dark-side Forum or Faceless book.
As Lorna has explained elsewhere:
If you would like feedback about dealers, parts suppliers or a garage, then you're welcome to post on the forum to ask for feedback. Your post will then be locked, with a request that all feedback is sent by private message.
Based on previous experience, this is so people can be frank about their experience and the forum remain free from arguments or threats. All opinions expressed are the responsibility of the individual.
Also you posted this "Yes the rules on here are weird and the moderators spend a lot of time locking threads (shutting stable doors) after an improper post has been made (the horse has bolted). I feel for them, as removing (or editing) the small number of dodgy negative posts would probably be less time consuming, and when a garage etc. gets lots of good public reports it should motivate other garages etc. to want to get similar reports."
Whilst I'm glad to read that you feel for the extra work that the moderators have to do, that feeling would be more plausible if you refrained from posting such incorrect drivel on the subject :roll: Just because you don't like the rule, there's no need to keep incorrectly repeating yourself.
Post by mikeonb4c » Wed Aug 19, 2015 4:34 pm
Thanks John, then I'll respond to people asking for advice about good dealers etc telling them what other have said. Or will the thread be locked before I can do that? I'm really trying to understand all this but the rules (or the interpretation of them) still seem in this case to be weird to me: I'm sure they were not intended to stop people recommending places they had heard good reports about from others on here. Did BF ever receive threatening calls after someone posted openly to say they had had (or posted openly to say they'd heard that others had had) good service from a place?
I hope the moderators will practice tolerance when someone continues to question what seems to them to be an illogical practice. We worked hard to promote tolerance on this forum - we don't want that to slip backwards.
I feel very uncomfortable having to take this stance on a forum I love (and being made to feel unwelcome for doing it, to be honest), but I still need persuading that our current practice is necessary or in line with the rules as conceived.
