lumpy running
Posted: Mon Aug 03, 2015 8:38 pm
by ribbleman
Hi All, Noticed lumpy running between 30/40 mph all other speeds
runs smooth? 2.5 diesel
thanx
Re: lumpy running
Posted: Mon Aug 03, 2015 8:53 pm
Has this suddenly started happening or is it a gradual onset? What happens if you put your foot down? Any black smoke? Does it drop a gear and take off well. Etc. Need to get a feel for what your problem is.
Re: lumpy running
Posted: Mon Aug 03, 2015 9:23 pm
by ribbleman
No smoke pulls away smooth has been noticed over about three weeks
owned 7 years never changed glow plugs.
Re: lumpy running
Posted: Mon Aug 03, 2015 9:39 pm
ribbleman wrote:No smoke pulls away smooth has been noticed over about three weeks
Faulty glow plugs might give lumpy starting from cold but shouldn't bother a warm engine. Gradual onset suggests its worth working through cheaper/simpler things: air filter, fuel filter, banjo filter in that order. If they've not been done for a while they're worth doing anyway. If problem persists, then start looking at fuel pump I reckon. But others more techie than me may have other thoughts. Good luck, keep us posted.
Re: lumpy running
Posted: Mon Aug 03, 2015 9:46 pm
by ribbleman
Regular servicing not done banjo filter will check it.
thanx
Re: lumpy running
Posted: Tue Aug 04, 2015 8:35 am
by rita
ribbleman wrote:Hi All, Noticed lumpy running between 30/40 mph all other speeds
thanx
It could be the heater relay dropping out, does this only happen when Cold or is it constant.
Re: lumpy running
Posted: Tue Aug 04, 2015 8:45 am
by ribbleman
Seems to be all the time
Re: lumpy running
Posted: Wed Sep 02, 2015 8:38 pm
by ribbleman
Hi All, progress report just returned from hols round western isles,
lucy never missed a beat 1500 miles cleaned banjo filter was quite
clean very happy.
Re: lumpy running
Posted: Wed Sep 02, 2015 10:54 pm
ribbleman wrote:Hi All, progress report just returned from hols round western isles,
clean very happy.
Great news. What do you reckon had been causing it?
Re: lumpy running
Posted: Thu Sep 03, 2015 3:29 pm
by ribbleman
Could have been fouled injector cleared after good run?.
Or perished pipe from air intake to top of fuel pump.
Re: lumpy running
Posted: Thu Sep 03, 2015 6:24 pm
ribbleman wrote:Could have been fouled injector cleared after good run?.
Hey ho at least it's fixed itself.
