front indicater not working
redz79
Post by redz79 » Tue Jul 28, 2015 5:31 pm
hi all
for some reason my drivers side front indicator has stopped working, its not the bulb, but the side light bulb on the same side is flashing instead, the meter says no power at the indicator bulb socket,any ideas ?.
rgds Ian
Re: front indicater not working
Post by g8dhe » Tue Jul 28, 2015 5:41 pm
I would suspect the earth connection for the lamps, if it lifts from ground then the indicator current will be flowing back down via the sidelights, which being lower power will flash more clearly than the indicator bulb itself.
redz79
Re: front indicator not working
Post by redz79 » Tue Jul 28, 2015 8:38 pm
thanks for the reply, I figured on it being some kind of earth issue, now to find the earth connection or maybe just make a new earth point, it took me some time to find the way into the bulb, It looked like the headlight unit had to come out !!. I removed the mazda dvd player out of the van at the weekend maybe that upset something, that was just a block connector.
rgds Ian
Post by g8dhe » Tue Jul 28, 2015 8:48 pm
The wiring diagrams have an earthing points page, both side lights and indicators use point 1 (JC-01);
redz79
Post by redz79 » Wed Jul 29, 2015 7:23 pm
thanks for the diagram, it is an earth problem, I ran a new earth to a bolt under the bonnet, cut the green earth wire on the bulb holder and spliced the new earth in , put the bulb back in and nothing !!, so I trapped an earth wire down the side of the bulb in the holder and touched it to earth, the we have a flashing bulb, so it looks like a bad earth in the bulb holder, now the fuse has blown, next question , which fuse is it ?, I have the owners hand book that just tells me where the fuses are .
rgds Ian
Post by Simon Jones » Wed Jul 29, 2015 8:28 pm
It's worth printing the factsheet off and tucking it inside the handbook in case you blow a fuse on your travels: http://www.igmaynard.co.uk/bongo/member ... usebox.pdf
Post by g8dhe » Wed Jul 29, 2015 8:37 pm
The http://www.g8dhe.net/bwm click this link and then choose the Tab you want, "By fuse problem" I suggest Then LIGHTS turn/Hazard lights ...
redz79
Post by redz79 » Thu Jul 30, 2015 6:43 pm
thank you for all the help, its all fixed now, new earth wire spliced in and a dodgy bulb holder seemed to be the problem , no corrosion in the holder, the terminals are very flimsy, gave them a clean and bent them out a little and alls well, need to get a selection of spare fuses , what size fuses do you suggest.
rgds Ian
ps hayden coolant alarm arrived today so its back out with the circuit tester at the weekend !!
zippy
Post by zippy » Thu Jul 30, 2015 7:44 pm
The cables can corrode. Mine did had to patch one front indicator.
Toyota Alphard - Bongo spirit
Post by g8dhe » Thu Jul 30, 2015 8:28 pm
redz79 wrote: what size fuses do you suggest.!
See the fuses on the "Fuse Type" Tab here http://www.g8dhe.net/bwm
Also Ian does a set in the shop of the smaller fuses.
