Air con oil leak
Posted: Sat Jul 25, 2015 12:37 pm
by TheStinkyHippy
I have found a couple of drips of oil here..
Pretty sure this is the rear heater air con pipes, as when I run the air con one pipe gets very cold.
The oil is a light colour, def not condensation and it is oily.
Could this be an air con leak, or does some other oil flow through here?
Re: Air con oil leak
Posted: Sat Jul 25, 2015 1:01 pm
by Simon Jones
Those are the A/C pipes although normally they would be silver in colour as they are made of aluminium (perhaps they've been undersealed?) and any oil would typically be bright green in colour. There are two different sizes of O-ring that contained within that joint and it's quite a common failure point. A decent air con engineer will be able to sort it out for you.
Posted: Sat Jul 25, 2015 2:53 pm
by rita
Its always worthwhile trying to nip up the set screws (bolts).You never know it might cure the leak.
Good Luck.
Posted: Sat Jul 25, 2015 7:59 pm
by Gasy
That's pipe lagging on them isn't it , insulation
They all should be lagged
Sure mine are
Posted: Sat Jul 25, 2015 8:22 pm
by Simon Jones
Pipes should be lagged but the fittings on the end are exposed aluminium.
