Fitting remote central locking / alarm
Posted: Fri Jul 10, 2015 4:20 pm
I'm looking for a bit of a guide to fitting remote central locking or an alarm. I need to fit a solenoid to the drivers door and I need to fit a kit.
The first bit that has me confused is that there are 2 types of solenoid - a 2 wire slave solenoid and a 5 wire master solenoid. Logic would make me think I would need a 5 wire master solenoid, but 2 companies I have spoken with said I need the 2 wire slave solenoid. However they couldn't explain why
- Are they correct and can anyone explain why?!
I found a guide in the members area on here for fitting the solenoid - mechanically I should be fine - other than getting my hands in but electrically the pictures weren't that clear. It also doesn't include all the other stuff for remote locking. In fact what does adding a solenoid on it's own do? I presume the bit that tells the others to lock isn't in the passenger door - so surely just adding a solenoid as per the guide would do nothing?!
Any way - does anyone have a bit of fitting guide for dummies?
Does a RCL kit all just wire up in the drivers door? Is it just a case of having a module which takes power from somewhere, then tapping into the wire that is activated when you turn the key so that when the remote is pressed - the doors all unlock?
If I add an alarm does it add a lot of work? Just thinking that an alarm kit is only £10 or so more than a RCL kit. However if I need to install loads of wiring to use it, it might not be worth it.
Thanks!
Thanks!
