Hello all.
On braking the brake pedal pulses a little, this happens on normal braking. The ABS light goes out etc as it should so it doesn't report a fault. Vehicle stops as it should, feels confident but this didn't happen before so there must be a problem ! Any ideas. Brake fluid normal quantity.
This happens all the time now, not an intermittent fault.
Thank you !!
best
Tony
Brakes pulsing!
Re: Brakes pulsing!
Warped disc maybe? Been doing any heavy braking followed by leaving foot on the brake pedal, as they say this causes uneven cooling and can trigger it.tcasc wrote:Hello all.
Thank you !!
best
Tony
