Changing front springs
Posted: Mon Jun 15, 2015 10:13 am
by Puma931
Is it possible to change the front springs without removing the strut?
I was thinking if you remove the front wings you could remove the springs with the bottom of the struts still in place and therefore no need for an alignment check??
Re: Changing front springs
Posted: Mon Jun 15, 2015 10:30 am
by nth
Why would you need an alignment check after removing the strut ? if you don't undo the locknut on the track rod end the tracking adjustment should not alter.
