im still biting at the bit for the black beast
does any one else run 20'' alloys ?
or what problems do you foresee
they are on a tin top and marked 97 y rating
im asking for full views - so no holding back lol
Moderator: Ian
francophile1947 wrote:Those tyres are 2.72% larger than standard, so will affect your speedo's reading. However, I have not found any tyres, of that size, that have a load rating of more than 95, whereas the Bongo requires a minimum limit of 96 on the rear wheels. Also, they would give a very hard ride
Just realised the black one in your photo is the beast in question (thought the wheels looked big) . Monster monster machine mate - I'm too square for all that but it does look impressiveandyb36 wrote:francophile1947 wrote:Those tyres are 2.72% larger than standard, so will affect your speedo's reading. However, I have not found any tyres, of that size, that have a load rating of more than 95, whereas the Bongo requires a minimum limit of 96 on the rear wheels. Also, they would give a very hard ride
as I like the styling etc - I am expecting the harder ride - but time will tell when I test drive etc
we will see - in time
gotta think of the 200 mile round trip 1st and time to do it
I found 17" wheels and 55 profile put my speedo spot on. I suspect 20" wheels will cause under-read whatever profile Andy uses. Just need to be carefulvilguy wrote:Regarding making speedos under read etc due to the change in circumference :-
The standard speedo overreads by a couple of % anyway so if you get it to be more accurate this can only be a good thing.
At 60mph my speedo reads 64mph via gps.
