Leisure Battery Charger
2newbies
Post by 2newbies » Sat May 16, 2015 3:12 pm
Hi everyone,
We're looking to put a small charger for the leisure battery permanently under the bonnet. The battery is fitted with a Willinton kit. Can anyone recommend a good one?
Thanks in advance and as always :)
Paul and Claire
c1rider
Re: Leisure Battery Charger
Post by c1rider » Sat May 16, 2015 8:01 pm
I fitted a Numax 10A charger, eBay item number 321156058628, a year or so ago and it's been fine so far. The only observation is that it has a variable-speed fan that can be quite loud if there's a bit of a load on it, but I've fitted it in the cab so it can't be too loud!
2newbies
Post by 2newbies » Sat May 16, 2015 8:36 pm
Thanks for that. With the Willinton kit can I just hotwire it into the terminals of the leisure battery without doing any harm?
TVM
Paul
Post by g8dhe » Sat May 16, 2015 10:54 pm
Make sure its fused at both the battery end as well as the charger end!
B12ROCK
Post by B12ROCK » Sun May 17, 2015 4:46 pm
I've just fitted a ring rsc408 behind the passengers seat hard wired to the leisure battery. Just plug it in to the 240v when required, only used it once so far but seemed to work OK. It has a supply mode for when you are running a load off the battery It only cost £40 from ebay.
c1rider
Post by c1rider » Tue May 19, 2015 8:22 pm
Yes Paul. There won't be any conflict with the Willinton kit, but be sure to fuse it as g8dhe said
