air con which do I have?
zippy
Post by zippy » Mon May 11, 2015 6:24 pm
I have the none climate control air conditioning
How do I tell if I have a 2 stage or single stage air con?
I have the vents in roof that work in rear and the panel behind my cuboard where the seat row use to be.
Toyota Alphard - Bongo spirit
Re: air con which do I have?
Post by g8dhe » Mon May 11, 2015 8:09 pm
Why do you need to know ? As far as I know its a single compression stage.
zippy
Post by zippy » Tue May 12, 2015 12:42 am
Unsure, as the fact sheet says.
"Re-gas system using R134a. The system will take approximately 950g (for dual system) or 700g (front system only)."
wonkanoby
Post by wonkanoby » Tue May 12, 2015 7:58 am
yep but they both run of a single pump
2 stage a/c to me relates to homes or offices
Post by g8dhe » Tue May 12, 2015 10:09 am
The Dual applies to having both front and back systems working as built, however some people block of the rear system when they remove it during a conversion, in which case less refrigerant is required to fill the system. Sounds like yours is standard and requires the full 950 grams of refrigerant.
zippy
Post by zippy » Tue May 12, 2015 10:14 am
So all the rear air comes from just that top vent? No wonder it's like a jet engine ( •‿• )
scanner
Post by scanner » Tue May 12, 2015 10:36 am
No you can choose where it comes from.
There are top vents and also bottom vents on the side panel under the rear control panel.
zippy
Post by zippy » Tue May 12, 2015 11:04 am
Ok, I still got that panel, and the rear switch in front.
Any others locations in back?
Top, side panel with control unit, and?
zippy
Post by zippy » Tue May 12, 2015 7:20 pm
Anyhow topped up and all fridgey.
