Split charge relay?
xt600
Split charge relay?
Post by xt600 » Mon May 11, 2015 5:46 pm
Has anyone any comments on this unit?
http://www.ebay.co.uk/itm/181160779765? ... EBIDX%3AIT
jimmo62
Re: Split charge relay?
Post by jimmo62 » Mon May 11, 2015 5:52 pm
Crimp type fuse holders are pretty unreliable in my experience as they don't have proper spring-loaded contacts to connect to the fuse blades. Worth getting proper fuse holders if you can
Post by g8dhe » Mon May 11, 2015 5:53 pm
Its rather underrated for the job, 40Amp minimum and 60Amp if at all possible I would suggest, for a caravan with only a fridge its just about adequate, for a Bongo, using lights, radio, fridge, blinds then it might not last very long.
xt600
Post by xt600 » Mon May 11, 2015 9:21 pm
Yeah, I like the sound of the Cyrix relay but it's quite expensive when you add all the bits together. The Bongo gets such little use. Not sure whether I can be tempted by one of these cheaper kits ;-)
mikexgough
Post by mikexgough » Tue May 12, 2015 5:39 pm
I had a Willinton charge kit..... the relay chattered at odd times so I swapped out the relay, but using the Willinton hardware for a 140 amp Durite split charge relay.... just under £40....well worth the money...
Dodgey
Post by Dodgey » Tue May 12, 2015 11:43 pm
I'm about to make a new kit that handles more than 30Amps. Will be out in a couple of weeks.
30Amps does the trick nicely, but if you flatten your LB too much it'll pop the fuses in a blink.
