40.8 MPG achieved
BongoBongo123
40.8 MPG achieved
Post by BongoBongo123 » Mon May 04, 2015 2:45 pm
Did a 470 mile round trip this weekend and managed 40.8 mpg on the way (sped upa bit on the home run to 60mph so it probably dropped a bit on that leg of the journey) I have the 2.5L diesel.Used brim technique.
16.36L consumed = 3.6 gallons = £19.96
147 miles traveled with 1 stop
147/3.6 = 40.833
Also had double dose of Millers Diesel Power Ecomax in there. (£2.00 worth) Average speed 54 mph.
So that is £21.96 cost with the Millers additive.
I am well happy with that.
They call me light foot.
silage
Re: 40.8 MPG achieved
Post by silage » Mon May 04, 2015 4:38 pm
" The harder you work, the richer you die"
97 4WD 2.5 TD
G0JZW
BongoBongo123
Post by BongoBongo123 » Mon May 04, 2015 7:54 pm
silage wrote:????
winchman
Post by winchman » Mon May 04, 2015 8:01 pm
Have you checked the speedo and milometer against a sat nav?
BongoBongo123
Post by BongoBongo123 » Mon May 04, 2015 8:02 pm
No but it closely tallies with a google earth mileage as per the route I used to close to where the petrol station was.
Post by mikeonb4c » Mon May 04, 2015 9:40 pm
I managed the same bb123 and no-one believed me either. But it definitely can be done =D>
Post by Bob » Mon May 04, 2015 9:45 pm
Well done, Guys. =D>
BongoBongo123
Post by BongoBongo123 » Tue May 05, 2015 10:14 am
Thanks Bob 8) I don't doubt it Mike. It was mainly M25 and A303 (not exactly the flattest of roads either) I drove specifically in mind with maximum economy and no traffic jams helped. I did 39 mpg last year with traffic jams and an urban detour cause of the jam en route to Wales.
I usually do 55-60mph but find 50-55 mph = maximum Bongo efficiency.
If your engine is not mangled anyone with a diesel can do it. :shock:
1) Correct tyre pressures
2) Well maintained engine with good quality oil (2 mth old Magnatec right now) and clean air filter
3) 50-55mph
4) Anticipate least safe breaking required when coming to roundabouts (if any)
5) Smooth gentle acceleration
6) Millers Diesel Eco max additive (which has cumulative usage benefits over time IMO)
7) I run a can of BG244 fuel injector cleaner 6 months ago. (high strength cleaner)
8 ) No air con - you lose 2-3 mpg or so as it is engine driven in part
The additives can pay for themselves many times over in 1 year and are significantly cheaper than adding supreme diesel.
I will find out what the emissions are like as it is in for MOT today. Be interested to see if they have dropped from the previous year.
al & chris
Post by al & chris » Tue May 05, 2015 11:19 am
Might have to try some of the millers additive. I do and always have used reddex in all my vehicles, not sure if it makes a difference but never had any probs with an engine that we have used in. All high mileage 15000 a year including bongo.
BongoBongo123
Post by BongoBongo123 » Tue May 05, 2015 3:09 pm
al & chris wrote:Might have to try some of the millers additive. I do and always have used reddex in all my vehicles, not sure if it makes a difference but never had any probs with an engine that we have used in. All high mileage 15000 a year including bongo.
Sounds good, never tried Redex before but the Millers made a small immediately obvious difference all round. Smoother running, better starting, slightly quieter and better economy and/or power.
No word on MOT yet.
BongoBongo123
Post by BongoBongo123 » Tue May 05, 2015 4:16 pm
Off topic but failed MOT on 1 point...offside front suspension arm, being sorted for reasonable price by my local Bongo experienced garage. Shame not a straight pass but could be a whole lot worse than that!
Post by rita » Tue May 05, 2015 4:36 pm
BongoBongo123 wrote:Off topic but failed MOT on 1 point...offside front suspension arm, being sorted for reasonable price by my local Bongo experienced garage. Shame not a straight pass but could be a whole lot worse than that!
Good result, what sort of reasonable price ?
Post by mikeonb4c » Tue May 05, 2015 4:57 pm
I achieved my 40+mpg without any additive so not sure its essential. The right conditions are helpful though I suspect as a good charge to the turbo might be a key element and that would be affected I guess by atmospheric conditions. Type of driving/roads is obviously a key factor.
BongoBongo123
Post by BongoBongo123 » Tue May 05, 2015 5:40 pm
What is a charge to the turbo mean Mike?
£85.00 rita
Post by rita » Tue May 05, 2015 6:06 pm
BongoBongo123 wrote:What is a charge to the turbo mean Mike? Probably means Turbo Boost .....From the Turbo.
£85.00 rita
£85.00 is a very good price for a lower suspension arm (Wishbone) even without fittin,, is that a second hand one.?
