				broken aerial
				Posted: Sat May 02, 2015 2:57 pm
				by silage
				Have found that the van aerial has got caught up on a low branch and snapped, its a rubbish design anyway, so is there an better out there mod wise? just wondering before i have to fit the same thing to snag again!
silage
				Re: broken aerial
				Posted: Sat May 02, 2015 3:43 pm
				by Gasy
				Yes people have removed the snapped bit
And one of them short rubber bendy ones fits over the stub left of the old original
It's on here somewhere
				Re: broken aerial
				Posted: Sat May 02, 2015 3:46 pm
				by silage
				Cheers gasy, will look again
				Re: broken aerial
				Posted: Sat May 02, 2015 4:01 pm
				by helen&tony
I think a few members have used something similar to this:
http://www.ebay.co.uk/itm/Alloy-Bee-Sti ... 2572ce89da
Cut the old one flush, screw one of the adapters in , and pop the aerial on.
You might have to find one with a base diameter to match the stub left on yours, and fill the side to match, but it should look O.K. The above is just an example...poke around on e-Bay
				Re: broken aerial
				Posted: Sat May 02, 2015 7:44 pm
				by Northern Bongolow
				as the guys and helen has said when the aerial breaks off it will leave a short section of hollow tube, this is ring crimped on to a brass stub by machine, if you carefully remove the remainder of the tube to expose the brass stub you can then drill and tap a hole in this to accommodate one of the adapters shown in helens link then fit a stubby aerial.
best to do this while still on the van cos if you remove the pivot you may lose the spring and little ball bearing that clicks when raised and lowered.
				Re: broken aerial
				Posted: Sun May 03, 2015 7:20 am
				by helen&tony
Ta, Ady...
Now it's clear what you have to drill and tap!...Are those aerials any better than the original?...I seem to recall advice for and against???
				Re: broken aerial
				Posted: Sun May 03, 2015 10:27 am
				by westonwarrior
				Re: broken aerial
				Posted: Sun May 03, 2015 11:09 am
				by helen&tony
Oh...that's the thread I remember
 ...Truth to tell, I couldn't get my brain together to search...too much pain today...but at least it's lovely and warm, so I'll soak up some sunshine!
