Does a 1995 Bongo starter motor require any servicing?
For example, oiling, without removing from vehicle.
There would appear to be two plastic grommets on mine.
On EBay there are two separate listings for a new BONGO 2.5 TDI starter, both less than £90.
Has anyone any experience with these units?
Starter Motor
- Junior Bongonaut
Starter Motor
BonGoRANT10
1995 SGL3 2WD AFT green/silver
- mikeWalsall
Re: Starter Motor
A common failure are the contacts in the starter solenoid .. a very simple cheap(ish) fix ...
Readily available (look on eBay) and many Utube tutorials ..
- Simon Jones
Re: Starter Motor
There are two types of diesel starter motor: standard and the North Japanese version fitted to the twin battery version. There are differing opinions in inter-compatibility.
