Fuse question.
bongoroy63
Fuse question.
Post by bongoroy63 » Sat Apr 11, 2015 6:51 pm
Whilst carrying out some work on my Bongo I have managed to blow the main fuse located behind the battery. The fuse is a100amp male PAL type so I need to replace it. However, I have checked in the Fury shop and see the highest amperage fuse is 60 amp. Is it safe to replace mine with a lower amperage or do I stick with the 100 amp?
I can, I do, I did.
Re: Fuse question.
Post by g8dhe » Sat Apr 11, 2015 6:54 pm
No - You need the bolt in 100Amp blue ones available from Amazon etc.
http://www.amazon.co.uk/s/ref=nb_sb_nos ... p+PAL+blue
check the type of bolt hole used open or closed end, if your not sure the open ended will always work.
bongoroy63
Re: Fuse question.
Post by bongoroy63 » Sat Apr 11, 2015 7:02 pm
Thank you Geoff. Question answered!
I can, I do, I did.
bongoroy63
Re: Fuse question.
Post by bongoroy63 » Sat Apr 11, 2015 7:11 pm
Just looked at the link sent by Geoff. One further query. I see there are a few to choose from but there is also one that says 'Japanese type'. Which one should I go for?
I can, I do, I did.
Re: Fuse question.
Post by g8dhe » Sat Apr 11, 2015 9:57 pm
The spare ones I carry are not marked Japanese! Hadn't even noticed that wording on some of the adverts to be honest, no idea what its significance is either! The ones I carry are the type below, but I've not had to change one on my vehicle yet either ....
