Key won't alway come out!
Posted: Sun Apr 05, 2015 3:09 pm
by silage
Ok, me again, Barri has taken a liking to holding on to the key at the end of a journey. I put brake on and put gearbox in to Park, it normally means another sort trip down the road to reset something before the key will come out!!!!!
It not all the time just when its going to be bloody annoying and cause friction between Mrs silage and me
any ideas O wise one's
Re: Key won't alway come out!
Posted: Sun Apr 05, 2015 4:21 pm
by scanner
Sounds like the gear selector interlock is playing up, just try putting it in and out of park a few times to see if that helps.
Posted: Sun Apr 05, 2015 5:30 pm
Check and adjust the cable 46-300 in the diagram below;
Posted: Sun Apr 05, 2015 7:06 pm
by silage
Thanks, any info on adjusting cable? plus location etc.
Posted: Sun Apr 05, 2015 7:11 pm
Well the location is the front of the gear selector, take off the central console etc.
Also see here
http://www.igmaynard.co.uk/bongo/forum/ ... 34#p587734
Posted: Sun Apr 05, 2015 7:18 pm
by teenmal
Hi silage, did you get your new ignition key?.
Posted: Sun Apr 05, 2015 9:09 pm
by silage
yes new key for wife to use, she don't drive,only me mad
, but go her one to be able to have access if im not around.
Posted: Sun Apr 05, 2015 9:26 pm
by scanner
silage wrote:yes new key for wife to use, she don't drive,only me mad
Tip...
Use the new one yourself for at least a while to wear it in a bit.
Posted: Sun Apr 05, 2015 9:55 pm
by teenmal
scanner wrote:silage wrote:yes new key for wife to use, she don't drive,only me mad
Tip...
Sound advice.....
Posted: Tue Apr 07, 2015 7:37 am
by silage
yes will try that, all so put switch cleaner in to key switch and seems ok at mo, but good to have another option with cable if problem returns.
Posted: Tue Apr 07, 2015 7:54 am
by Simon Jones
Graphite dust from a pencil is a good trick to lubricate a sticky key. Be careful about using switch cleaner as it will wash out the lubrication already in the lock.
Posted: Tue Apr 07, 2015 12:23 pm
by silage
Good point
