Oil on the Engine Block following Overheating
Posted: Mon Mar 30, 2015 9:48 am
Hello Bongonauts,
Having bought my first Bongo early February this year and having put about a 1000 mile on it already, I assumed all was well.
I should have paid attention to the signs. They were there.
Last Friday I prepare the Bongo for a short one night trip. I did not get far before the temperature gauge was off the scale. Turns out there was little to no water in the cooling system.
The Bongo had sat for about 3 weeks without being driven or having the engine turned over.
The signs...
Having started the Bongo to raise and lower the roof I noticed a small (7cm in dia.) patch of fresh oil on the ground under the gearbox. Soon after there was (only) a few drips of water coming from under the radiator. After driving for roughly 3 miles and parking the radiator fan remained on. 3 miles later the temperature gauge was off the scale!!!
I parked up, opened everything, let the Bongo cool and having noticed that the header tank was empty topped it up.
Taking the chance I started the Bongo up and cautiously drove back home. With water in the cooling system... all appeared to be fine. The temperature was good and the Bongo was performing as I would expect it.
Did I get away with it!?
Anyway - I am not trying to write a short story here... my question to all you very experienced and capable Bongo Mechanics is...
What do you make of the attached photos? Ah... how do I attached pictures?
Ok a description...
On the drivers side there appears to be a significant amount of fresh engine oil on the engine block from the cylinder head/engine block line down. What is this indicative of?
Do I have a blown Cylinder Head Gasket? The fact that I have put 1000 miles on the Bongo without a problem and the oil patch appeared on the ground before the engine was up to temperature might suggest not.
My thoughts were to give the engine a good clean, find and fix the water leak and take the Bongo on a short trip while keeping an eye on fluid levels and periodically checking the engine for oil leaks.
My fear is that I could do some serious damage if I have not fully appreciate the route cause of the initial issue and the potential subsequent damage!
Again, your experience and expertise on the subject would be greatly appreciated.
Thank you in advance,
David
The signs...
Ok a description...
David
