Page 1 of 3
EGR System blanking
Posted: Thu Mar 26, 2015 1:15 am
by al & chris
Thinking about blanking off the egr system and looking at old posts looks like quite a few of you have done this in the past.
Is anyone now having problems after doing this. Reading other posts on the web looks like there could be a link to blanking off and turbo problems, or is this just rubbish. Looking long term and high mileage could there be any link?
Re: EGR System blanking
Posted: Thu Mar 26, 2015 1:21 am
by Bob
Mine was blanked off soon after we got it 7 years ago, no probs so far, and we tow a caravan.
Contact Allans in Plymouth for plates.
Posted: Thu Mar 26, 2015 6:23 pm
by Tony x
Well worth doing for a bit of mid range boost in power plus a recent post suggested it makes the engine less fussy on the oil you might use.
Engine will generate a bit more heat but this should not put you off as it won't overheat due to a blanked of EGR
Posted: Thu Mar 26, 2015 6:33 pm
by Gasy
Is there a step by step guide for fitting these
Going to do mine soon
Posted: Thu Mar 26, 2015 7:09 pm
by al & chris
Tony x wrote:Well worth doing for a bit of mid range boost in power plus a recent post suggested it makes the engine less fussy on the oil you might use.
Any other advantages/disadvantages people know of. How much hotter will engine run.
Posted: Thu Mar 26, 2015 7:15 pm
by jimmo62
Gasy - there is a fitting guide here http://www.allansvehicleservices.co.uk/shop/
I have not done this myself so can't comment on the accuracy of the guide though.... But Allans seems to have a good reputation
Posted: Thu Mar 26, 2015 7:34 pm
by Bob
Very good reputation. 8)
Posted: Thu Mar 26, 2015 9:10 pm
by briwy
There's a few pictures here of ours when I did it. Later model but basically the same layout.
http://www.igmaynard.co.uk/bongo/forum/ ... t=blanking
Posted: Thu Mar 26, 2015 10:07 pm
by Northern Bongolow
best thing ive ever done to my motor. also diverted the crank/rocker cover breather pipe, this goes into the air intake pipe at the rear of the head, made mine like the old mini,s the pipe goes to ground level. all this makes the engine breathe clean fresh cooler air resulting in a cleaner burn once warmed up and a better bang as the cooler air is denser.
115000 miles and no crud or oil leaks, plus my engine oil and filter now last 2 years. 8) 8) .
Posted: Thu Mar 26, 2015 10:41 pm
by Diplomat
I've got a feeling this might inspire a few of us to undertake a fairly simple spring project, even if we are of the 'if it ain't broken..' school.
Frank
Posted: Thu Mar 26, 2015 11:07 pm
by al & chris
Northern Bongolow wrote:best thing ive ever done to my motor. also diverted the crank/rocker cover breather pipe, this goes into the air intake pipe at the rear of the head, made mine like the old mini,s the pipe goes to ground level. all this makes the engine breathe clean fresh cooler air resulting in a cleaner burn once warmed up and a better bang as the cooler air is denser.
So diverting rocker breather should offset slightly higher engine temp caused by blanking off?
Posted: Thu Mar 26, 2015 11:26 pm
by bongoroy63
Sorry for my ignorance but what is an EGR???
Posted: Thu Mar 26, 2015 11:29 pm
by Simon Jones
Posted: Thu Mar 26, 2015 11:35 pm
by bongoroy63
Thanks Simon. Just had a quick look at the link and it seems a bit heavy for this time of night. I'll read it and digest it at a more appropriate time!
Posted: Thu Mar 26, 2015 11:39 pm
by Simon Jones
Yeah, I gave up after the first paragraph :)
