The garage says my turbo waste gate valve is not receiving a signal from the ECU. The garage wants to know if there is a vacuum pressure sensor for this valve, and if so, where is it on a new-shape 2003 Bongo?
Regards, Rick
my bongo engine warning light is flashing
rocketeeer
- Bongonaut
Re: my bongo engine warning light is flashing
HI, you need to get your mechanic to make sure that the vehicle actually has a waste gate valve, it is very possible that this year of vehicle has the Variable Vane or the VGT system controlled by a vacuum actuator.
Good Luck.
Good Luck.
- Simon Jones
Have a read thru the linked topics: http://www.igmaynard.co.uk/bongo/forum/ ... =+Variable
rocketeeer
- Bongonaut
Many thanks, folks. How do we tell whether my turbo diesel bongo has this variable vane (VGT) or just a waste gate valve?
- Simon Jones
Variable vane turbos were fitted from round about 1999/2000 onwards. Looking at the schematic diagram, you don't seem to have a wastegate. I believe the excess boost is disapated by the VV moving to reduce the amount of air compressed.
rocketeeer wrote:Many thanks, folks. How do we tell whether my turbo diesel bongo has this variable vane (VGT) or just a waste gate valve?
Normally the actuator will be positioned to operate Vertical on the VV/VGT and with a waste gate valve fitted it usually is in a horizontal position.
Never take things as granted ....always check.
- Simon Jones
