Head pressure test
Posted: Sun Feb 08, 2015 5:51 pm
by Carlo
Hello Everyone
The water pump failed in my bongo and she overheated.
After this she has been starting lumpy with lots of white smoke, and not picking up on revs for at least 10 seconds from start up, this along with water disappearing from the tank with no leaks visible has led me to believe that the head gasket has gone, and possibly the head cracked.
So i have taken the head off (following the fact sheets from the members area).
Please can somone tell me where the best place to have the head pressure checked would be? I am from Somerton in Somerset.
Carl
Re: Head pressure test
Posted: Sun Feb 08, 2015 7:32 pm
by Northern Bongolow
they usually seem to crack around the exhaust valves on either cylinder no 2 or 3, is there any visible signs. they tend to go behind the valve seat up towards the stem seal so are hard to spot, you usually get one discoloured valve etc.
pressure testing does appear to be a little inconclusive especially if done cold, hot test sometimes shows it up.
put a straight edge along the rocker shaft bearings first, as ive seen them lift in the centre and snap the cam into 3 pieces when they over heat, then they are just scrap.
Posted: Sun Feb 08, 2015 7:48 pm
by Simon Jones
I took mine to Bellhill Garage at Norton St Philip who have a place that can pressure test at close to operating temperature. They can also supply you with the oil feed pipe that you ought to change as part of the preparation for refitting the head. Have a search for my posts on 'decking the block' for further info.
When you refit the head (current or new one) don't forget you'll need new head bolts and cambelt kit. Good luck.
Posted: Mon Feb 09, 2015 12:51 pm
by haydn callow
Somerton!! So am I, ADS Bristol are good, pressure tests are often misleading with these heads, almost certainly cracked I'm afraid....
Posted: Mon Feb 09, 2015 12:54 pm
by haydn callow
Examine the area around the exhaust valves....fine brown lines are a give away.
Where in Somerton are you??? I'm Behind Berry by the bus stop nearest the Fire station.
Posted: Mon Feb 09, 2015 1:48 pm
by Carlo
Thank you all for your reply, the head dose not seem to have any damage from heat at all, also with a precision edge the head has not warped.
To Hayden, we are at St Cleers Way. I cannot see any brown lines on the head. I will post some pictures on here when i can upload them.
Carl
Posted: Mon Feb 09, 2015 7:41 pm
by haydn callow
Our Jo who now runs the Bongo Low Coolant alarm business lives near there.
Posted: Thu Feb 12, 2015 6:04 pm
by Carlo
Posted: Thu Feb 12, 2015 6:09 pm
by Carlo
Thanks again to everyone. We have got the head back on and she is driving a dream, much better than when we first bought her, and so far has lost no water (must purchase a low coolant alarm from hayden)
Now all i need to do is drill and tap the exhaust manifold bolt that i sheared off, and cure the leak in the fuel injection pump (which i am not looking forward too as i have large hands)
Carl
Posted: Thu Feb 12, 2015 6:25 pm
by Bob
Sound job. :D
