New Headlamp bulbs
New Headlamp bulbs
In process of upgrading Headlamps. Osram Night breakers purchased. I will change one and give the lens a
good tooth pasting then compare.
Always be ready for a Top Up!
- BongoBongo123
Re: New Headlamp bulbs
Sounds interesting let us know how you get on. Are these ok in the Bongo, spec wise ?
Is there a model number for the Osram ones ?
I always thought the Bongo has very good headlights/beam at night but I have no idea what bulbs I have in mine. They are not the very white ones. These sound good and as if they would make the car appear more modern in the night and of course improve clarity of road vision.
They call me light foot.
I fitted the Night Breakers last summer and they are definitely brighter than standard, a simple and worthwhile upgrade in my opinion. I also polished the lenses with toothpaste at the same time which is also worth doing.
http://www.ebay.co.uk/itm/OSRAM-NIGHT-B ... 3a94cbcb78BongoBongo123 wrote:Sounds interesting let us know how you get on. Are these ok in the Bongo, spec wise ?
The whiter light bulbs generally do not last as long as ordinary bulbs as the bulb burns at a higher temp - hence the whiter light. Some whiter bulbs last longer than others though. And yes, I do use the whiter ones!
al & chris
- Tribal Elder
Think they are the ones we fitted. Yes they are brighter. We also fitted some ceramic connectors as someone said they are hotter and can damage the wiring.
Now you tell me.al & chris wrote:Think they are the ones we fitted. Yes they are brighter. We also fitted some ceramic connectors as someone said they are hotter and can damage the wiring.
dont worry baz ive had em in both of ours for 2 winters, one did pop this winter so swapped both out. the wires/connectors have given no problems mate.
Tried to put photo on but photobucket keeps wanting me to update Flashplayer so sod it. Put em on Face bollx
Put my Night Breakers in over 3 years ago after recommendations on here.Best bulbs by far.
- BongoBongo123
Love the good tips on here !
Once those are in our Bongo's will look:
I can also recommend the night breaker bulbs. They're a worthwhile upgrade.
Beyond A to B
Just FYI, Nightbreakers are on offer at £17.99 with free LED torch at Eurocarparts at the moment....
