Getting HOT underneath hand brake ?
Posted: Sat Jan 24, 2015 3:29 pm
by Graham
Temp gauge ok and water level fine.
Re: Getting HOT underneath hand break ?
Posted: Sat Jan 24, 2015 4:47 pm
by mikeWalsall
Maybe wise to check the insulation on the engine cover is OK ..
BUT ... as the handbrake lever is situated above the rear of the engine the metal will warm up .. that's also where the scavenger fan switch is located .. if it was to hot the fan would (should) automatically turn on ..
Posted: Sat Jan 24, 2015 6:15 pm
by Northern Bongolow
check the exhaust manifold isnt leaking.
http://www.igmaynard.co.uk/bongo/forum/ ... ifold+stud
Re: Getting HOT underneath hand brake ?
Posted: Sun Jan 25, 2015 1:17 pm
by Simon Jones
It does get warm (for obvious reasons) but unless it has changed from what you are used to then I would not be unduly concerned.
