Corner Sensor
Posted: Sat Jan 17, 2015 3:53 pm
by spookmaria
Hi guys another newbie question after replacing reversing switch in gear box i was expecting the corner sensor to work but it still is not operational. i now think it may be the well worn switch on the dash, any ideas where i could get a replacement? Thanks in advance
Re: Corner Sensor
Posted: Sat Jan 17, 2015 5:43 pm
by Northern Bongolow
do you mean the front near side corner sensor??
Re: Corner Sensor
Posted: Sat Jan 17, 2015 9:21 pm
by spookmaria
No we only have rear corner sensors.
Re: Corner Sensor
Posted: Sat Jan 17, 2015 11:14 pm
by francophile1947
If they are parking sensors, they will be an after-market item, as they were not fitted as standard.
Re: Corner Sensor
Posted: Sat Jan 17, 2015 11:27 pm
by Simon Jones
They were a factory option. Geoff has them (as I recall). There is an LCD display on the dashboard and one at the top of the tailgate window.
Here's a photo of the front display that is from a listing on Gumtree. The rear is the same but hangs upside down from the roof.
Re: Corner Sensor
Posted: Sun Jan 18, 2015 11:12 am
Yup the original type fitted have three corners- not the drivers corner, and two rear facing sensors, the three work all the time its switched on and the two rear facing come in to play when reverse is selected as well.
Re: Corner Sensor
Posted: Sun Jan 18, 2015 2:16 pm
by llitvack
In Simon's catalogue the front nearside corner has a parking pole attached (what's called 'corner guide' in Japanese katakana).
I still have a parking pole, complete with motor, on my van. We used to have one of these on our Honda Civic when we lived in Japan. I'd love to reactivate the one on my Bongo! I don't recall anyone on the list resurrecting theirs recently, though I know this has been a topic on the Forum in the past.
Cheers from Leon
Re: Corner Sensor
Posted: Sun Jan 18, 2015 3:11 pm
by Simon Jones
I think a lot of them end up with the motor failing due to their location where it gets a good drenching.
Have you got the corner guide switch and if so, does it do anything? You could try applying 12v direct to the motor and seeing if it moves.
Re: Corner Sensor
Posted: Sun Jan 18, 2015 3:59 pm
by llitvack
I don't have the switch, Simon; but I will try applying 12v to the motor some time.
Americans seem to like these for their old Hondas. There's a company called JDM which made them; see
http://www.icbmotorsport.com/jdmek4sirek9.html
and
https://www.youtube.com/watch?v=zI5ajLN_klc
Re: Corner Sensor
Posted: Sun Jan 18, 2015 4:08 pm
they usually fail because they have a strimmer type plastic line inside, when the motor turns it winds the line in/out, this line gets age hardened and snaps into pieces.
Re: Corner Sensor
Posted: Sun Jan 18, 2015 5:59 pm
by Bob
Something from an automatic ariel may sort it. [-o<
Re: Corner Sensor
Posted: Sun Jan 18, 2015 6:20 pm
by llitvack
This looks interesting; but it's overkill: :shock:
http://www.tribalwhipsstore.com/
Re: Corner Sensor
Posted: Sun Jan 18, 2015 6:31 pm
by Bob
Tribal Whipstore caught my attention for a second there. :shock:
