front washers (not working)
Posted: Mon Jan 12, 2015 12:42 pm
Hi all,
purchased a replacement (front) washer motor from Ebay. Local garage fitted it (apologies not that technical).
However, they didn't charge me for fitting it - said the motor was fine. Therefore assuming it is likely to be a wiring problem (can't be fuse, cos wipers still work fine).
Any tips/hints pointing me in the right direction - much appreciated
