Radio standby current on leisure battery
Posted: Tue Dec 02, 2014 9:54 pm
I've connected my car radio to the leisure battery so I can use it when camping. So I have both the main supply for the radio plus the memory backup supply connected to the LB all the time.
The problem with this setup seems to be that the radio never really goes into standby - it's pulling about 200mA all the time when turned off at the switch on the unit. I'm assuming that in a normal car setup, when the ignition is turned off and the radio only has a feed to the memory backup, the radio goes into a very low power mode. But if the ignition lead is on then it is in some sort of warm standby mode drawing the higher current so it's ready to start immediately perhaps.
Has anyone seen and/or managed to get around this problem - I could put a switch in of course but then I'd have to remember to turn it off every time I didn't want it. Has anyone found a model which does not draw so much current when powered from the LB? Any other ideas? 200mA is too big a drain if I'm away for the weekend without a hookup because it's draining all the time whether I'm in the van or not......
