				Leisure Battery not charging
				Posted: Thu Oct 02, 2014 10:55 am
				by stark
				In Brief
Bongo Fitted out by 123away a few years back and has been faultless.
This summer the Leisure Battery went bye bye and gassed off. Bought a new one and fitted it and everything works lovely again.
But now the battery needs charging after about a month or so despite the van being used, so i'm wondering if there is an issue with the charging but have no idea how to check this.
any ideas?
				Re: Leisure Battery not charging
				Posted: Thu Oct 02, 2014 11:25 am
				by janie
Is it a split charge relay - if so there should be an in-line fuse that might be a good starting point
				Posted: Thu Oct 02, 2014 12:43 pm
				by stark
				Trouble is i literally have no idea where to look for that . eg engine compartment/dash/somewhere else??
				Posted: Thu Oct 02, 2014 4:31 pm
				by wonkanoby
				follow wires from l/b back
				Posted: Fri Oct 03, 2014 8:22 am
				by Mark.T
				I spent a while going from zero knowledge to finding the problem on mine (a fuse!).  I found it by searching the internet and comparing what I found with that under the bonnet and I managed to track down the problem with the help of a multimeter/voltmeter (essential).  Try this for starters ..
.. and then carry on through these .. (< click)
A little vague, but a split charge system can done in different ways and wires can be routed in many different ways, so without photos of yours it's difficult to pinpoint.
Hope that helps.
				Posted: Fri Oct 03, 2014 8:33 am
				by stark
				cheers guys.
i'll have a rummage around this weekend to see if I can track down what is amiss
				Posted: Fri Oct 03, 2014 3:48 pm
				by Dodgey
				Do you have a zig unit with a switch that says towing and on site?  If so then make sure its on towing when you want the lb to charge whilst driving.
