Rear roof interior light..
Posted: Sat Sep 27, 2014 8:13 pm
Totally puzzled..
the rear roof light is very dim. This is with both the original tube bulb, and an LED replacement. Occasionally it bursts into life, as it should do, but quickly reverts to a 'glower'. Have sprayed switch cleaner in there, jiggled and jiggled, taken apart and checked all connections, but no luck.
Interior lights, 12v sockets and radio are running off the LB, which shows 10v without engine running. Other interior lights are ok, it's just the rear roof light that's acquired this problem. Presume not a fuse problem, as it does work, but not 'up to speed'.
Suggestions gratefully received..
Derek
Derek
