Over active soft close
Posted: Wed Sep 24, 2014 9:41 pm
I've had a search on the forum, but found no answer, so here's a new post
When we bought our Bongo, the soft close didn't work on the sliding door, so I cleaned up the contacts and it then 'worked' every time. The problem now is that it continues to try and close, releasing and pulling in the door for a while afterwards. It will also randomly try to close the door now and then.
Is there a switch that tells the door that it's shut and it can take a rest!? The switch on the end of the door seems OK as it turns the light on inside and I haven't noticed the light trying to come on (though I've only really driven in the day light).
Any ideas?
1999, AFT, 2.5 V6
Any ideas?
1999, AFT, 2.5 V6
