corroded brake disk
Posted: Sat Sep 13, 2014 10:49 am
Hello again,
I have just had new boots fitted to my "el bonguito" and the dude happened to mention that he was concerned about the offside rear brake disk. All the others are nice and shiny all the way across but this one is corroded at the edges of the disk and only looks 'rubbed clean' in the centre portion.
I don't use el bonguito too often and the disks tend to develop a nice coating of rust between uses which then comes off after a little driving. This hasn't happened on this one disk. My guess is that it just got too corroded.
Should I be concerned about this? Should I get a new disk fitted and be more careful to keep it clean or just forget about it? He mentioned that it would probably fail its MOT.
Thanks for the advice!
James.
James.
