Front blower questions.
Posted: Sun Sep 07, 2014 4:31 pm
I am not a technical minded person when it comes to cars.
I noticed yesterday that my front heater/cooler blower stopped working.
I checked a little bit on the internet and when I take off the plastic air inlet thing I can see the plastic motor top (?) within the big filter. When ignition is switched off it rotates freely. If the ignition is on and I touch it and move it a little then it will spin, until I stop and then it's 50/50 chance if it comes back on spinning again.
Once I manually start it spinning I have control and it will go at the different speeds.
I assume it needs a little lubrication so have put a little WD40 on the screw at the top hoping it will drip down.
Since using the WD40 it seems to be working apart from once or possibly twice.
What else do folk suggest and is it simple to remove this by using the single screw on the top?
Thanks in advance.
Alan
Thanks in advance.
Alan
