Battery drain
Posted: Sun Aug 03, 2014 12:02 pm
Had the dreaded.. key in.. click.. chug.. nothing..
Jumped from other car, started first time... went for a 15 minute drive.. all seems ok.
Alternator is giving around 13.6v to SB when running.
I connected voltmeter to check for parasitic drain.. found it is drawing around 0.043Amps (43milliamps)
LB is having around 0.083Amps draining.
Bongo is configured for fuses 1,6,7,8 to LB.
I tried pulling all cabin fuses one at a time, only one that made difference is fuse 17 (Sliding door) that seems to be drawing 0.003amps.
I pulled the engine IGN fuse and that stopped the 0.040 draw.
After pulling IGN fuse
Any idea what to check next?
Or is 0.043 ok?
Or is 0.043 ok?
