Rear Heater Not Working!
Posted: Sat Aug 02, 2014 7:20 pm
Hello all - new Bongo owner here needing some advice if you're able to help!
I have a 1996 AFT with side conversion where the heater slider controls have been mounted on the bottom of the side conversion however the rear heater isn't blowing out either hot or cold. I've checked the fuses and they are OK but can't work out how to access the rear of the control panel on the conversion without lifting it out! Also it has a Monitor fitted in the rear and extra 12V sockets and noe of these work either so i suspect it's something electrical.
Does anyone have a clue as I don't - I think the Bongo is great and am off to France in it next week with 8 year old grandson so cooling / heating in the rear and a working monitor would be a boon to say the least!
