engine oil
Colin H F
engine oil
Post by Colin H F » Fri Jul 25, 2014 2:02 pm
Simple question folks looked in the manual but I cant seem to find where to top up the engine oil in my 2.0 litre petrol 2000 model, I know where the dipstick is but not the filler cheers
mikeWalsall
Re: engine oil
Post by mikeWalsall » Fri Jul 25, 2014 2:10 pm
#10.250
Re: engine oil
Post by Muzorewa » Fri Jul 25, 2014 2:12 pm
It's on the other side under the driver's seat :wink:
On the diesel the dipstick & filler are both on the same side. On both petrol models they're on different sides as the engines weren't specifically designed for Bongos. On a normal motor once you've opened the bonnet, it doesn't matter which side the dipstick & filler are on.
Colin H F
Re: engine oil
Post by Colin H F » Fri Jul 25, 2014 3:03 pm
cheers does it hinge back like the passenger side as i have a side conversion right up to the drivers seat. ok sorted cheers
Re: engine oil
Post by Muzorewa » Fri Jul 25, 2014 3:18 pm
Just drop the seat on the steering wheel, should give you enough space
Re: engine oil
Post by Simon Jones » Sat Jul 26, 2014 10:06 am
Sometimes, if accessibility is tricky, it can be better to remove the seat which is only held in place with 5 bolts and one connector to disconnect.
mikeWalsall
Re: engine oil
Post by mikeWalsall » Sat Jul 26, 2014 11:37 am
On my V6 with a side conversion .. I tip my seat back as far as I can .. then prop it up with a peice of wood (bottom left in pic.) ..
