drivers side inner wing relays S reg diesel.
Posted: Mon Jul 21, 2014 6:45 pm
by Northern Bongolow
Re: drivers side inner wing relays S reg diesel.
Posted: Tue Jul 22, 2014 9:38 pm
anyone ???
Posted: Tue Jul 22, 2014 10:14 pm
by Simon Jones
Only relay I can see on drivers wing is glow plug, but cant see it would be that:
Posted: Tue Jul 22, 2014 10:41 pm
i will ask muz to photo them------ there is more than one on his driverside inner wing.--------very strange, maybe geoff could help.
Posted: Wed Jul 23, 2014 5:44 am
by Muzorewa
Will take photos this evening
Posted: Wed Jul 23, 2014 5:52 pm
by Muzorewa
Well here they are, they're tucked away beside the starter battery. There are three, the one nearest the headlamp does all the clicking when the gears are worked.
Posted: Wed Jul 23, 2014 7:04 pm
by Gasy
Mines an r reg
And I have 3 same as muz
Carnt see the top of closest one but the rear one has H310 on top of rubber cover
Didn't someone put a picture up once with them labeled on what was what
Did that have 3 on drivers side?
Posted: Wed Jul 23, 2014 7:20 pm
cheers paul.
the 3 that geoff usually shows are on the passy side if im not mistaken.
this link to a later motor shows some on the driverside, maybe muzzes is a changeover model that has later goodies added even though its old shape.
http://lushprojects.com/bongopartsmk2/c ... no=.html#6
Posted: Thu Jul 24, 2014 8:30 pm
by nth
Maybe the inhibitor relay that stops you starting the engine if its not in P or N ??
Thats the only relay i can think of off hand that would be operated when the gear lever is moved.
Posted: Thu Jul 24, 2014 9:16 pm
it maybe that but the relay operates when moving from any gear lever position to any other,its got me this one.
no doubt its obvious, but
Posted: Thu Jul 24, 2014 10:16 pm
by Simon Jones
You could always unplug it and see what happens?
Posted: Fri Jul 25, 2014 9:08 am
by Muzorewa
On the later ones, I think ours was one of the first, there's a gear indicator on the dash as well as the gear selector. Not that relays would be needed but might it be connected with this?
Posted: Fri Jul 25, 2014 7:25 pm
Sorry lads only just found this been using the tablet all week and not the laptop;
The starter relay is in that position (or should be they can be moved around of course), that shouldn't be operating on gear shifts!
Next relay in is rear de-froster;
Can't see anything using the third position, but net is a bit slow out here!
Posted: Fri Jul 25, 2014 7:31 pm
by Gasy
Muzorewa wrote:On the later ones, I think ours was one of the first, there's a gear indicator on the dash as well as the gear selector. Not that relays would be needed but might it be connected with this?
Mines not got the gear indicator in the dash
Mines r reg
And has the 3 relays on drivers side
