Rad hoses
Posted: Sat Jun 28, 2014 9:56 pm
by bongobridge
Hi guys,
Just after a bit of advice I have had a small leak on the bottom hose on the rad, after changing the hose there is still a small leak coming from the hose.
Question is , Can there be some kind of sealant used when replacing these hoses??
Re: Rad hoses
Posted: Sat Jun 28, 2014 11:01 pm
by haydn callow
No.....not really.....stick another jub clip on or get a Norma hose clamp from the website below.
Re: Rad hoses
Posted: Sat Jun 28, 2014 11:26 pm
by Simon Jones
Is the leak due to a poor seal or is it coming from the pipe itself? Most joints don't need sealant but where there can be corrosion on the metal components preventing a good joint, I use a smear of Hylomar blue compound.
Re: Rad hoses
Posted: Sun Jun 29, 2014 1:14 am
by bongobridge
Thank Simon, Haydn
It is a bad seal so will try the hylomar, it has two jubilee clips on and it's a new pipe but still dripping .
Nick
Re: Rad hoses
Posted: Sun Jun 29, 2014 5:07 pm
by teenmal
Strong possibility that the radiator is leaking, check the radiator stub and bottom tank seal.(if plastic type)
Does it have metal tanks or plastic type.
