correct tyre pressure
Posted: Sat Sep 16, 2006 4:03 pm
by buddha
dear all,
having scoured the forum for the past hour or so,i am still none the wiser,so here goes. i realise that the subject seems to be done to death and then some. i have a 2wd shod with 205/55zr16 rubber on alloys. can anyone help me with the correct tyre pressure please?
cheers.
Posted: Sat Sep 16, 2006 5:35 pm
by David Edwards
Hi I suppose it varies but I have ordinary steel wheels that were on as standard I have 215's all round and put 32 front 34 rear. There should be loads on it in the weird search facility. Hope it helps. Happy motoring
Posted: Sat Sep 16, 2006 8:02 pm
by Simon Jones
Try "psi" in the search - there are many relevant threads listed
Posted: Sat Sep 16, 2006 8:27 pm
by Dave up north
Does it not say on the tyres????
Posted: Sat Sep 16, 2006 8:53 pm
by Simon Jones
Its relative to the weight of the vehicle to get the right handling
Posted: Sat Sep 16, 2006 8:54 pm
by Dave up north
Oh heck!
That'll be mine wrong then.
I know... I'll just pump em up untill they are round
Posted: Sat Sep 16, 2006 9:58 pm
by Athers
Dave up north wrote:Oh heck!
Dave, i hope you haven't got 205 psi all round!!!!! :shock: :shock:
Posted: Sun Sep 17, 2006 11:27 am
by waycar8
speaking of your wheels dave, did you get your brakes checked or are they ok now? has the rust on the passenger side disks gone now, or was it the drivers side?
Posted: Sun Sep 17, 2006 12:11 pm
by Dave up north
Checked em often since then and its a strange one.
They all get shiny with use and this is to be expected.
But if I dont use the van for a couple of days, its the drivers side that colour up with rust first.
Might be that the passenger side got coated with cooland when the rad cap failed, but it has me stumped.
Might also be that I park with the passenger side sheltered.
Just dont know.
Although it brakes fine and straight.
Posted: Sun Sep 17, 2006 8:46 pm
by Athers
It is perfectly normal for discs to 'rust up ' as mentioned. It is not just a Bongo thing. They are just big lumps of steel at the end of the day!
Ford Mondeos are very good at it........don't worry!
Posted: Mon Sep 18, 2006 9:45 am
by Kentish Paul
Yes, perfectly normal. The slightest moisture in the air (e.g. dew) will spot them with rust, it does not have to have been raining. And yes, often one side is more prone depending on exposure, wind direction etc.
There is a Toyota dealership at the top of my road. They havebrand new cars in the open which are immaculate apart from rust on the discs! Depending on the exact construction, some discs are more prone than others.
Nothing to worry about.
