Noise from engine
Posted: Mon Jun 23, 2014 9:11 am
by TheStinkyHippy
Hi all.
Billy has developed a strange noise. (2.5 diesel 95 model)
Normally this noise is heard when the engine is running, but very occasionally it happens when the key is put to ACC position.
Managed to video it this weekend. It only made the noise for about 20 seconds and then stopped.
Video is taken from under the passenger side. I was wondering if it was the alternator, but the noise happening without engine running makes me think it can't be.
http://youtu.be/SfLEn48CNeI
Video is only a few seconds long.
Anyone have any ideas?
Many thanks.
Re: Noise from engine
Posted: Mon Jun 23, 2014 9:23 am
by wonkanoby
sounds more like a fan than engine to me
check the scavenger fan below front of engine
Posted: Mon Jun 23, 2014 9:28 am
by TheStinkyHippy
wonkanoby wrote:sounds more like a fan than engine to me
When does that kick in? I have never seen it moving.
I tried to rotate it and at first it wouldn't move, but then it finally did.. but never seen it move.
Posted: Mon Jun 23, 2014 10:09 am
by wonkanoby
key put to a/c means it could be one of fans on radiator
they come on wirth a/c
scavenger should only come on with extreme heat
Posted: Mon Jun 23, 2014 10:57 am
by TheStinkyHippy
wonkanoby wrote:key put to a/c means it could be one of fans on radiator
Thanks for the pointer. It is the scavenger fan.
Found the sensor by the handbrake and by passed it, fan comes on and is noisy.
Tried to add oil, and it seems to make it worse.
Looks like it is slipping. Looks loose around the center.
Any idea how to take the blade out? The nut in the center just turns with the motor.
Posted: Mon Jun 23, 2014 11:03 am
by wonkanoby
looks buggered to me
im guessing some thing got in and locked fan,but motor carried on spinning
a breakers your best bet like the famous george on ebay
Posted: Mon Jun 23, 2014 4:33 pm
by Steptoe
Don't suppose a liberal application of araldite would effect a temporary repair?
Posted: Mon Jun 23, 2014 4:35 pm
by TheStinkyHippy
Steptoe wrote:Don't suppose a liberal application of araldite would effect a temporary repair?
I found some bits of plastic hanging off. Looks like the fan has stripped.
bongospares had one for £35. Ordered and waiting delivery. Hopefully it will be easy to fit
Posted: Mon Jun 23, 2014 6:44 pm
by Northern Bongolow
sounds like someone may have wired it direct in the past, so it is on permanently, its not designed for prolonged/constant use so may have eaten itself.
ive had bongo,s for years and have never seen one switch on/off yet.
