Headlights rapidly dimming or dying - dodgy connection?
Posted: Fri Jun 20, 2014 11:38 pm
Hi guys
When I put headlights on they turn on then rapidly fade or die. Both headlights together. Side lights are ok as is high beam. Suspect it's a dodgy connection or wire that's failing once current heats it up. Is this a common fault and if so does anyone have any idea where to check first?
