PLEASE HELP!? Changed timing belt now Bongo V6 won't start
AndyBB
Post by AndyBB » Mon Jun 16, 2014 4:49 pm
Hi everyone, please, please can anyone help. I have had my 2.5 V6 Bongo's timing belt changed and camshaft seals but now she won't start. My local garage said they have checked the timing over and over and that it isn't out, they've changed the spark plugs, new oil and filter but nothing. It turns and it did try to fire twice but then nothing. The compression test come back and they're averaging around 85 to 110.
The mechanic has now said it might be a problem with the o/s lifters because I used a Wynns Lifter Concentrate to quiet them down as they had a slight rattle.
Please if anyone can offer advice it would be very much appreciated. She's LPG converted and drove and started prefect before all of this. She's been off the road for 3 weeks.
Andy.
jimmo62
Re: PLEASE HELP!? Changed timing belt now Bongo V6 won't sta
Post by jimmo62 » Mon Jun 16, 2014 9:05 pm
Sounds like a case of working through logically.
Make sure that the garage has detailed information on the timing marks and setup, they need to refer to the manual not guess from the marks.
Work through the usual ignition faultfinding checks - is there a spark? Is the spark timing correct (e.g. distributor may have moved). Are the plugs connected in the right order on the distributor? Do they have the correct plug type/reach?
Is there fuel getting to the cylinders (sorry not sure if it's injection or carb on the V6), do the plugs get wet?
Are there any sensors which control the ignition - check for fault codes in case a sensor has gone down - perhaps emission sensor?
Post by Doone » Tue Jun 17, 2014 4:22 pm
Allan has replied to the email from your garage.
And he's assumed your mechanic has checked all the usual culprits. :)
foxuke
Post by foxuke » Fri Apr 17, 2015 7:22 pm
Was this resolved? If so how? I have a what might be a similar problem.
Foxuke
Ukulele madness in a Bongo wrapper!
Post by mikeonb4c » Fri Apr 17, 2015 7:37 pm
Did I read this problem can result from a goosed crankshaft sensor?
