Is this run off the leisure battery or the engine battery ?
Thinking about a 12V fan.
Ciggy lighter...
Moderator: Muzorewa
- BongoBongo123
Ciggy lighter...
They call me light foot.
Re: Ciggy lighter...
Must be engine battery as I have not got a leisure one and both my cig sockets (front and back) work fine? Unless someone has done a little fiddling with yours?
If you have a L/B then the sockets are very often the first circuit switched over to the L/B along with the radio etc.
- BongoBongo123
Thanks yes I have a LB under the bonnet is there an easy way to identify which batteryg8dhe wrote:If you have a L/B then the sockets are very often the first circuit switched over to the L/B along with the radio etc.
of the 2 is the leisure battery ?
- mikeWalsall
We have seen one vehicle with the S/B and L/B swapped around at 2013 Bongo Bash!! Needless to say the installation was very poor and nothing had been connected to the L/B either ....
- BongoBongo123
