WHY DOES THE FAN START WHEN IGNITION IS ON
Posted: Wed Jun 11, 2014 10:57 pm
by Jonny Tunnel
Not sure whats up, but Bongo fan goes on when i put ignition on, without even starting the engine. Engine is cold, hasnt been used today.
Its a mystery ready to be solved..
cheers Jonny
Re: WHY DOES THE FAN START WHEN IGNITION IS ON
Posted: Wed Jun 11, 2014 11:08 pm
by Driver+Passengers
Jonny Tunnel wrote:Not sure whats up, but Bongo fan goes on when i put ignition on, without even starting the engine. Engine is cold, hasnt been used today.
cheers Jonny
Which fan?
Radiator fan(s) or the scavenger fan just in front of the engine?
The sensor connections to check, respectively, are:
- temperature sensor low down towards the rear of the engine block on the driver's side
- sensor just behind the handbrake, poking down into the engine bay
Both sensors feed the ECU, which controls the fans.
Posted: Wed Jun 11, 2014 11:13 pm
by Jonny Tunnel
Ok thanks, what should i be checking for?
Posted: Thu Jun 12, 2014 12:09 am
First off, which fan... then first checks are free - are the connectors attached, corroded? Otherwise, checking the wires, testing the sensors themselves...?
Posted: Thu Jun 12, 2014 12:41 am
by Simon Jones
Rad fans will also come on when A/C is engaged.
Posted: Thu Jun 12, 2014 1:13 am
I removed "are the blowers on" from my original post thinking myself rude, but if A/C was also on...
Posted: Thu Jun 12, 2014 8:06 am
by Simon Jones
In theory, A/C compressor will only engage when engine running, so it ought not to be that. My guess would be the engine bay sensor is open circuit resulting in the scavenger being on, but its not clear from the OP which fan is being referred to.
Posted: Thu Jun 12, 2014 3:10 pm
by Jonny Tunnel
Im sorry i dont know what the scavenger fan is.
A/C is defo off
Posted: Thu Jun 12, 2014 3:19 pm
by Simon Jones
Big one in front of the engine (roughly where the gear lever is). Then there are two more traditional fans behind the radiator.
Posted: Thu Jun 12, 2014 7:36 pm
by Jonny Tunnel
i can hear it quite clearly so im guessing its the scavenger fan
Posted: Thu Jun 12, 2014 7:49 pm
If you lift up the driver or passenger's seat - you can see the scavenger fan, just in front of the engine - angled slightly up the way. The radiator fans are bolted onto the back of the radiator, and harder to see (though you can feel the air with the seats up).
Posted: Thu Jun 12, 2014 9:41 pm
by Jonny Tunnel
Nice one D&P, ta
