Mazda Rx8 Alloy Wheels 225/45/18 - will they go straight on?
Posted: Tue Jun 03, 2014 8:51 pm
by donaldthomps
Hi - will these go straight on a Bongo?
Thanks, D
Re: Mazda Rx8 Alloy Wheels 225/45/18 - will they go straight
Posted: Tue Jun 03, 2014 9:11 pm
by Simon Jones
Check the load rating and ask your insurance company whether it will increase the premium. Also factor in that getting 18" tyres of the correct load rating (min 96) is not easy or cheap.
Posted: Wed Jun 04, 2014 7:27 am
by mikexgough
You will need to replace the tyres for 235/45/18 to get over the 96 load rating.... most 235's are 98's
235's will mean that the speedo will read 30.4 at 30 mph & 60.7 at 60 mph....
Many Bongo owners with 18's fit Nankang 235/45R18 98W XL AS-1
225's are either 91 or 95 load rating so not suitable for the Bongo...and your insurance company will have an easy get out if you ever needed to claim...
Posted: Sat Jun 07, 2014 1:48 pm
by Titan1995
I have 18" RX-8 wheels with 225/55 tyres......transforms the handling of the Bongo.
Also helped when we were flooded a while ago with the wading aspect.
Only thing is front tyres wear fairly quickly.....
Posted: Tue Jul 08, 2014 12:24 pm
by CavemanClarke
What wheel nuts would you use to put the rx8 alloys on the bongo...?
Posted: Wed Jul 09, 2014 8:53 pm
by ELZE
Titan1995 wrote:I have 18" RX-8 wheels with 225/55 tyres......transforms the handling of the Bongo.
Better to rotate then at 3 month intervals to even out the wear.
Posted: Tue Jul 15, 2014 5:51 pm
by Mark Norton
I too have RX8 ALLOYS with 235/50 R18 budget tyres Achilles Desert Hawk H/T101V 149MPH 825KG's rated. No wheel arch fouling. My speedo reads under compared to sat nav e.g. 48mph on speedo actual speed 50mph, so no problems there. Wheel nuts have had to be done up tight to torque 147N.m (108 ft-lb) and wheel balancing and tyre pressure has proven critical to eliminate all steering judder.
I noticed a slightly harsher ride and reduced acceleration, possibly better fuel economy. No I would not go back to the standard wheels, the RX8 alloys transformed the look of the van, next time I will be going for the higher 235/55 tyres and will trim the front wheel arch.
Posted: Tue Jul 15, 2014 7:15 pm
by Simon Jones
Mark Norton wrote:My speedo reads under compared to sat nav e.g. 48mph on speedo actual speed 50mph, so no problems there.
That is illegal/not technically roadworthy (or however the rules may be enforced/interpreted). The speedo can read over by up to 10% but can never read under.
http://en.m.wikipedia.org/wiki/Speedometer
Posted: Tue Jul 15, 2014 7:44 pm
by Mark Norton
Sorry wrong way round, I will be doing a dead 50 on the speedo through road works or speed restrictions on the motorway and I will be under the sat nav speed by at least 3mph. I need to do over 50 on the speedo to be actually at 50mph.
Posted: Tue Jul 15, 2014 8:52 pm
by Simon Jones
Phew :)
Posted: Wed Jul 23, 2014 11:15 am
by cmm303
And the spare? Elsewhere I've seen somebody suggest a wheel off a Mazda 6 - does that mean they fit as well?
If 4wd rolling circumference needs to be the same as well as fitting.
Posted: Wed Jul 23, 2014 12:36 pm
by stuc
donaldthomps wrote:Hi - will these go straight on a Bongo?
Thanks, D
Hi Donald, why were you asking in the first place? The wheels on your van were really nice when I saw it.
Stu
Posted: Tue Jul 29, 2014 8:39 pm
by Luke and Debs
hi all i run 235/50/18 on rx8 have load rating of 101 fitted to a bmw x5
ride really nice
cheers luke
