Page 1 of 2
Roof board.
Posted: Fri May 30, 2014 11:21 am
by Jonny Tunnel
I have recently bought a Bongo, but the rear roof board is missing. Can anyone kindly tell me the dimensions, and what material i should use to make one please.
Also, what is the red switch to the right of the button below steering wheel next to switch that says 'Rear'.
Kind Regards
Re: Roof board.
Posted: Fri May 30, 2014 12:21 pm
by Simon Jones
Is it proper roof or aftermarket? The AFT roof does not have a removable rear panel:
The switch you described is likely to be rear foglight.
Re: Roof board.
Posted: Fri May 30, 2014 5:44 pm
by Jonny Tunnel
Yes its an AFT roof as shown in your pic. The board is missing, perhaps somebody yanked it off.
Thanks also for advice re: switch.
I'll prob make a temporary board out of ply.
Regards Jonny
Re: Roof board.
Posted: Fri May 30, 2014 7:27 pm
by Simon Jones
Theres one for sale here: http://www.ebay.co.uk/itm/mazda-bongo-e ... 233a48f5f2
You may also need the gas struts if the whole lot has been removed.
Re: Roof board.
Posted: Sun Jun 01, 2014 9:33 pm
by Jonny Tunnel
No its the internal part of the roof that i need, rear section.
Thanks anyway
Re: Roof board.
Posted: Sun Jun 01, 2014 9:41 pm
by Simon Jones
I can't visualise the part you mean. There's only the removable front section and lift up panel with the integral hatch. Can you highlight which part it is on this diagram?
http://lushprojects.com/bongopartsmk2/c ... 1of02.html
Re: Roof board.
Posted: Mon Jun 02, 2014 9:08 am
by rita
Is it the floor covering panels you are looking for.........69-8R3/69-8R2A ETC
Re: Roof board.
Posted: Mon Jun 02, 2014 11:24 am
by Jonny Tunnel
Yes this is correct, rear floor panel. Sorry i didnt explain well, i dont have a manual yet to help either.
Re: Roof board.
Posted: Mon Jun 02, 2014 11:40 am
by Jonny Tunnel
Yes looks like 69 8r2a.
Re: Roof board.
Posted: Mon Jun 02, 2014 11:51 am
by rita
Your best bet would be to contact a breaker, cant imagine that they will be expensive, not a lot of call for this item.
Good Luck.
Re: Roof board.
Posted: Mon Jun 02, 2014 12:33 pm
by Jonny Tunnel
Thanks Rita, i'll have a look for breakers!
Re: Roof board.
Posted: Mon Jun 02, 2014 1:26 pm
by Simon Jones
The parts shown as 69-8xxx are grey headlining material panels which are like pieces of felt or carpet glued to the inside of the AFT. Can you post a photo showing where the thing you are looking for should go?
Re: Roof board.
Posted: Mon Jun 02, 2014 2:19 pm
by Jonny Tunnel
Hi not sure how to put up photos, have u an email i could send pic please.
cheers Jonny
Re: Roof board.
Posted: Mon Jun 02, 2014 3:05 pm
by Simon Jones
PM sent :)
Re: Roof board.
Posted: Mon Jun 02, 2014 5:43 pm
by Simon Jones
Thanks for the email Jonny. The item you need is the front roof board which fits over the front cab section. It is drawing number 57-480A in this diagram. You'll probably be able to get one from a breaker. Update you profile with your location & we can probably recommend somewhere close to you. If you get stuck, I know a man who will probably have one ;)
