Hand Brake Indicator Light On
Paul Eden
Post by Paul Eden » Fri May 09, 2014 11:49 am
My 2002 Freda has an intermittment fault where the hand brake indicator light will come on for up to a minute intermittently when driving (normally after actual braking), and go off again.Anyone any ideas what might be causing this?
Thanks.
Driver+Passengers
Re: Hand Brake Indicator Light On
Post by Driver+Passengers » Fri May 09, 2014 12:11 pm
Underneath the plastic center console between the seats - there should be a small push switch with connector/screw at the rear of the handbrake. Check the connection, it may be loose - mine was - prevented me from raising the roof!
Image Image
mikexgough
Post by mikexgough » Fri May 09, 2014 3:32 pm
Sounds like Brake fluid level dropped..... probably due to worn Brake Pads... best check both of these...
Post by Simon Jones » Fri May 09, 2014 5:34 pm
I don't recall seeing a level sensor on the side of the master cylinder, but this is a good place to start the checks. There are no brake pad wear sensors fitted so that can be ruled out.
Paul Eden
Post by Paul Eden » Sat May 10, 2014 12:48 pm
Thanks for all your suggestions. Fluid and pads seem okay, so will check the connection.
Tony x
Post by Tony x » Sat May 10, 2014 8:33 pm
We had exactly this issue....but on a 1998 Mazda 323f.
All that was needed to fix it was topping up the brake fluid reservoir.
I reckon this is your issue as the light only came on in the 323 when driving and using the brakes.
Paul Eden
Post by Paul Eden » Sun May 11, 2014 8:48 am
Thanks for that. My brake fluid reservoir is about half way between the min and max marks, so I thought that was okay, but I will try topping up anyway to see if that gets rid of the problem.
Paul
Post by teenmal » Sun May 11, 2014 9:06 am
Hi Paul,
The fault sounds like it could be a Vacuum and or Vacuum switch problem, best to get this checked out ASAP.
The Vac switch is on the front ,top , right hand side of the brake servo unit.
mikexgough
Post by mikexgough » Sun May 11, 2014 8:40 pm
From this thread.... http://www.igmaynard.co.uk/bongo/forum/ ... ht#p595980
Mikewalsall's post.... Shows a connector into the master cylinder..... haven't looked at mine but will do tomorrow..... out of interest
Post by teenmal » Mon May 12, 2014 9:45 am
I would be very surprised if your vehicle did not have this Safety device, even the Japanese fitted them as standard.
mikexgough
Post by mikexgough » Mon May 12, 2014 1:36 pm
teenmal wrote:I would be very surprised if your vehicle did not have this Safety device, even the Japanese fitted them as standard.
Indeed..... all I was indicating was that it has been said in a thread that there is a level sensor for the Brake fluid and that I hadn't noticed one on mine ( as I have never looked for one) ....needless to say I took a look at mine.
Paul Eden
Post by Paul Eden » Mon May 19, 2014 5:00 pm
It turns out that the simplest explanation was correct. My brake fluid needed topped-up, even though the reservoir indicator was okay.
Thanks for all your help.
Post by Simon Jones » Mon May 19, 2014 10:29 pm
I've checked mine today and can confirm there is a low level sensor on the offside of the reservoir. It looks to be quite a bit below the Min level line.
mikexgough
Post by mikexgough » Tue May 20, 2014 6:37 am
Paul Eden wrote:It turns out that the simplest explanation was correct. My brake fluid needed topped-up, even though the reservoir indicator was okay.
Always best to start with the simple things when investigating a problem..... :wink:
Glad the top up was all that was needed.... \:D/
Post by mikeonb4c » Tue May 20, 2014 7:40 am
But.....why was it low. I've never needed to top mine up in 7+ years. :roll:
