Power Steering Sticking?
Posted: Thu May 08, 2014 12:47 pm
by cossie
Hi All,
When driving along I can feel the steering wheel stick in my hands when trying to turn ,it then releases as normal .Only a recent occurrence and I have checked the levels on fluids and all okay.Any thoughts would be most appreciated as a long run to Cornwall coming up and it will give some time to hopefully sort it out.
Re: Power Steering Sticking?
Posted: Thu May 08, 2014 1:15 pm
by lancyman
Mine started doing this on Saturday. Looked on here
On it looks like a dry joint from steering wheel.
Look under bonnet and you can see a rod coming from
The steering whheel, and then the joint. Advised to clean
This with a hose, then lubricate with white lithium
Spray grease. Not done mine yet, but that seems worth
A shot.
Posted: Thu May 08, 2014 3:33 pm
by Bob
If you can't fix it book a visit to Allans, Plymouth.
Posted: Sun May 11, 2014 10:44 pm
by Jaws
"I have checked the levels on fluids and all okay."
In addition to all the advice already offered it might be worth changing the fluid in the power steering system. This is the same stuff as used in automatic transmissions and should be a clear red colour. If it looks dirty, change it.
Posted: Mon May 12, 2014 9:27 am
by teenmal
It is also worthwhile lubricating the (UJ) universal joint in the cab, you will see it on the steering rod/shaft under the dash.
Posted: Wed May 14, 2014 1:32 am
by Coradia63
I had the same problem lubricated the universal joint and it was ok for a few weeks then it started to stiffen up again so I bought a new joint when I took the old one off it was shot very stiff in one direction and a fair bit of wear steering feels brand new now
Posted: Wed May 28, 2014 7:15 pm
by cossie
Thanks to all who replied-managed to grease the joint and all appears well.
Posted: Thu May 29, 2014 10:57 am
by David Edwards
Similar thing happened with mine, I gave the uv joint under the bonnet..easy to find just follow steering road down,lol,... a good blasting with hose to clean off muck, then a good squirt with super maintenance spray..wd 40 evaporates too quickly, been fine since, I now give it a few squirts every week or so to keep it lubed,lol.
